阅读: 5065|回复: 0
[资讯] Acustica Audio(AA)2023.R2R 安装教程
发表于 2023-11-25 | |阅读模式
I have no idea if I did something wrong when installing the framework or when installing the plugin.
I am running on Windows 10.
Could someone explain to me exactly what I need to do to understand what I have done wrong?
I made a Folder in Appdata with Make_APPDATA_Acustica_Dir by R2R .
This Folder Exist and its Empty .
I have installed w_dpcpp_cpp_runtime_p_2024.0.0.49848 from R2R
I have copied The Files in the Folder : Acustica.Audio.Framework.2023.READ.NFO-R2R\Framework-R2R\Acustica\Framework to C:\Windows\System32
And i have made a new VST Folder on my C Drive for Acustica Audio Plugins that looks like this :
And i have Installed Microsoft Visual C++ Redistributable (2015-2022) x64 from here :
https://learn.microsoft.com/de-d ... edist?view=msvc-170
in Studio one i have set this Folder as a VST Folder but i cant find the FIRETHEPUMP Plugin
Best Answer
It seems like you got the location wrong for the folders :
AppData Location -> C:\Users\[yourname]\AppData\Roaming\Acustica
VST3 folder location --> C:\Program Files\Common Files\VST3
My suggestion create a folder "Acustica Audio" in the "VST3" folder to keep them tidy.
